khstudio
Kevin, what did you do to add gain control of the discrete output stage? I have read some of the previous posts on this and I'm not sure I understand correctly - replace R6 with a 10k log pot like this?
Yes & ground one side. Seems to work OK.
Fred said you could go directly into the 4.99k for un-balanced input but the more I think about it, I think i asked him about an input cap & he said something small... like 10uf or so. Not sure about a resistor to ground.
A small bypass cap across it... not sure, have to listen.
The 2604 DOES GET HOT... I think it's normal & should be fine.
BYPASS - I don't think you can get a full signal in bypass mode with this circuit unless you make a TRUE BYPASS WITH A SWITCH OR RELAYS.
The only way I found to work is run a test tone & note the level, THEN run it thru the FFO & adjust the output gain control (R6 - 10k pot) so the level coming out matches. (WITH GAIN REDUCTION OFF).
MARK THIS SPOT ON YOU GAIN CONTROL!
This was also helpful when comparing the RAW signal to what's going thru the FFO circuit. With NO GR, your just listening to the AMP SECTION of the FFO & can hear what IT'S doing to your signal. :idea:
