chunger
the "good" E80F that I found so far was Amperex. I think they all came from the same factory in Holland, no? Valvo, Amperex, Zarex, Philips, etc.
The E80F was only made by Valvo and was sold by the Philips mother company here in the US under the Amperex brand name as 6267.
chunger said:I have 1 out of 3 quiet tubes so far which makes it essentially a $60 alternate tube. I have not tested them in studio yet against the Amperex and Telefunken EF86's, but am burning in a couple to prepare.
MicDaddy said:chunger said:I have 1 out of 3 quiet tubes so far which makes it essentially a $60 alternate tube. I have not tested them in studio yet against the Amperex and Telefunken EF86's, but am burning in a couple to prepare.
Chung can you talk some on your method of testing? It might be helpful to describe a method of test that we can all perform similarly and do some correlation.
micaddict said:Oliver wrote this on the Neumann forum:
...Henk, I believe that Oliver referenced 6084 as the Amperex variant for the E80F...the 6267 is, as you said, an EF86...
micaddict said:...Henk, I believe that Oliver referenced 6084 as the Amperex variant for the E80F...the 6267 is, as you said, an EF86...
He does say 6267 here (twice), but going by heart he probably mixed them up. Unfortunately, we can't ask him anymore.
But it wasn't the point anyway.
http://www.neumann.com/forums/view.php?site=neumann&bn=neumann_archive&key=1015804332
ioaudio said:Hi Ben,
re-check the wiring - that should be the culprit - check all the connections between switches, acryl-part and pcb.
-Max
