[quote author="mediatechnology"]Peter - You may find this story interesting. Back when I worked for SSL we, like many other manufacturers, had to use Raytheon 5534s. These parts had this sputtering 1/f popcorn whatever you want to call it noise. They sounded awful.
...<snip happens>...
Raytheon channels, when nulled to each other, sounded very distorted. Pure grunge. Very IM-ish sounding.
Each channel from line in to mix went through perhaps 30 5534 gain stages.
Clients quickly understood what we were trying to accomplish replacing, usually at no charge, their Raytheon parts with Signetics.[/quote]
Word.
Wayne came to town (before I moved here) and commissioned a console for a mutual friend. Later on, this op-amp sonic performance cropped up, and I've a suspicion that our friend noticed the issues for himself...
As a result, Wayne prevailed upon SSL to send down a FedEx package of 5534s. A side-by-side comparison was performed, and the console was COMPETELY refitted. It was subsequently noted that some of the modules ALREADY had the better 5534s in them, while others contained the nasty Raytheon versions. Some modules were a mixture.
After the refit was completed, there were quite a few left over. They were kept as service replacements. The last of these are STILL in the original FedEx tube, which can -if necessary- date this documented occurrence, should anyone care to know more.
Wayne speaks the truth.
[quote author="CJ"]ok all you opamp brainiacs, which opamp has the worst frequency response of all time?[/quote]
A dead one.
Keith
