OK, after five years of staring at these WeCo miniatures, I finally found the hour it took to wire up as a micpre with the 417A.
It sounds great! What blew me away most was that with a 1:30 input transformer, the gain was about the same as a V72 or API/Melcor. And this is single triode.
It seems to have a lot of clear high end without the cathode by-passed, which might be useful, so I put in a switch for the cap. Vocals would sw the cap in, cymbals or field work (this would make a great tube/field preamp) sw the cap out.
Noise is great, and went way down when I dropped the B+, but the gain of course went down also. Which gave me an idea for gain control on a fixed gain preamp like the V72, as you would not have to disturb the circuit. Once in a while the tube acted up with a little hash, which is probably why it cost me a buck at the surplus. I have a few more I can try. I should have grabbed a whole shhopping bag of these, as they go for silly money on evilbay.
There is some high frequency ringing when the tube is tapped, way above what most tubes ring at. So I will shock mount the socket and maybe add a tube cooler.
Now I know what Aunt Gertrude was really listening to when she complained about a bad phone line. It was tube hash!
Bias sat at about a buck and a half with 250 B+.
Went to 75 cents with 125 B+.
Thanks to Bill Y for the DuKane, not a bad transformer at all. Bi-filar, and a nice mu can.
This pre was built from junk pile stuff, so it did not cost anything. I can't wait to record some stuff with it. Here is the schematic. Pardon the large jpg, stiill trying to figure out this new software:
This would make a great beginners tube micpre. One tube, one input x-former, two resistors, two caps, an xlr and a 1/4 inch output jack. I am, as always using an external pwr supply.
Let me know if you want some pics. Not much to see with that parts count.
I have plenty of rack left, so I think I will do another, only trying PRR's circuit, with the iron on the output instead. With 20 ma un-balanced dc, it's gotta sound cool!
cj
