[quote author="Learner"]hey CJ,
What exactly is the supply voltage?? 100V or 200V? and your bias current is 11mA!?? :shock: hmmm...... I would love to see the output on the CRO with a signal running through it, also the noise figure with closed circuit.
What is the gain of this tube?? I would not think it will be too high if the current is at 11mA.[/quote]
His gain was 10x, or 20dB, about the same as a 12AU7 or 6SN7. His supply voltage was 150 for 11mA.
Same case at the output, I have a resistor connected in series with the output coupling cap. This resistor kills both noise and gain, so its a compromise. Without it and with no FB for the tube, I get a sine wave like sort of noise at the output and its loud. I forgot to measure its frequency.....
Oscillation. Too long leads, too much junk around the tube allowing capacitative coupling from output to input.
How did you work out the bias, using load curve? Interested in replacing the plate resistor with a 500K ohm pot then run a 1khz signal through the tube, probe the plate coupling cap and tweak the plate resistor pot. Watch it on the CRO and see what value of the pot you arrive at to get optimum gain and minimum noise, you might want to add another 500K pot for FB as well, since it will help to flatten the noise you'll see it on the CRO!
That 500k pot instead of a plate resistor, and all the other high-impedance stuff around the tube, is causing the "noise" which is really oscillation. Read the earlier posts -- this looks like it's a pretty low-distortion tube.
I don't have cathode decoupling cap on any of my tubes because I found that it added noise, may be I didn't wait long enough until the noise settle down a bit after turning on the circuit. I might try that again.....
I also tried all different coupling caps and could hear NO difference, the only thing I find is that the biasing point is absolute critical to gain, noise and distortion which to me pretty much defines the sound. There is a optimum region for the value of plate R and FB R and screen R(in case of the Pentode), where by combining these 3 variables you can achieve maximum gain with minimal noise in comparison to every other combination of the 3 variables. I only tweak for max gain and min noise because there isn't much I can do to alter the distortion plus its really minimal, can not really see it on the CRO also to me it defines the personality of the tube as well as the characteristic of the sound.
The "noise" you're getting is oscillation. The actual noise generated by a tube circuit comes from:
1) Johnson noise (thermal) generated by the source impedance
2) ditto generated by the cathode resistor if it's unbypassed
3) ditto generated by the plate resistor in parallel with the load impedance, all divided by the square of the stage's gain
4) The noise generated by the tube itself; in a triode this is approximately 2.5/gm, where the gm (transconductance) is expressed in mho -- excuse me, Siemenses.
5) Hum from various sources
Really, try rigging up a really tight layout with a by-the-book plate and cathode resistor, and see what you get. No feedback resistor. I think you'll be surprised and pleased by the results.
Peace,
Paul
