[quote author="Gus"]What is the heater supply voltage?[/quote]
it *should* be 6.3VAC, right from the high quality Welter PSU 6.3VAC output (floating virtual earth). There's enough current reserve for a third channel if I want one.
checked just now, 5.7VAC!! what the heck? that shouldn't be right. :shock: If I had to guess it's my bad quality volt meter. I remember measuring it a month back and it was 6.1VAC. This far I've understood that a bit under or over the target voltage on the heaters might even help fight ground hum issues. That shouldn't kill tubes.
Can it be that when I turn on the unit it initially fires major over voltage on the heaters and this might slowly kill the 12AV7 over time? I mean, even lightbulbs always die on the initial fire up.
as for the bias supply voltages, those are within 1-5% of the target and AFAIK that's well within safe limits, and when it gets distributed to the all the stages it stays that way (just double checked).
I oughta drag this to someone with a decent oscilloscope.
