Hi all…
I'm saving up for a DIY kit, and in the meantime I've been reading and reading about electronics. I'm actually erring toward now inventing a gadget and building it - possibly as my first studio gear DIY build!
I've drawn up a little work-in-progress flow chart of processes my gadget needs, and I'm slowly ticking off understanding how to construct each step.
That said, I've got a couple of questions that I'm wondering about - perhaps someone here can assist in my understanding?!
1) Bufferring
I understand the basics of Unity gain buffering using an opamp. What I'm not 100% sure of is:
For perfect (within practical limits) signal integrity in splitting signals, would I need to have each split stage buffered IF I was sending the signal to another Op Amp for a process? I'm currently planning on splitting, separately processing and then recombining a rectified signal, and for my needs accuracy is key… I'm also planning to pop a unity gain buffer stage on each split and THEN sending it to another OpAmp for a particular process, but now I'm thinking "wait - if the next process is via another Opamp, does it effectively buffer / isolate the system?" … Hopefully that makes sense?! I'm a little stuck on understanding this part…
i.e. do I need to put a buffered unity stage before an opamp when splitting signals in a gadgets signal chain to avoid a minor voltage drop?
2) Rectifying…
Would a typical diode based rectification of a signal be relatively low damage to the signal… I've been reading into different diode arrangements, but not sure if I'm reading too much into certain types of diodes and how they affect voltage signals… basically confused again! So:
Can a diode based rectifier be low loss (or theoretically no loss), or will it introduce anomalies into a signal. I've briefly read through a few sites that manufacture IC style chips for rectifying… but I'd be happy with a handful of diodes if it works fine
3) General Op Amp reading…
I'm covering a lot of good reading via the net regarding the awesome different things that various Op Amps can do, but at times I'm a little short on detail. Is there a really good go-to resource anyone could recommend for understanding basics (the range of things they can do) and then technical stuff (equations etc.)… I'm happy with the web; but I'd also be happy with a book if there's an Op Ap Bible out there
Thanks for anyone's assistance
Jonny
1) Bufferring
2) Rectifying…
Jonny
