dirkwright
- Joined
- Mar 24, 2012
- Messages
- 83
Wow Jesper, that's an interesting approach. I'll have to experiment with it. Thanks.
audiomixer said:Is this a circuit you have actually build or just simulated? I'd think I could test that, but I would have to swap the transistors to what I have at hand.....
- regards,
Michael
- regards,
Michael
Harpo said:1st sight, the traces connecting to the 79xx (1-gnd, 2-in, 3-out) seem mixed up.
Why are the separate +/-supplies (2? rectifiers, regulators, ..) needed at all when you could use the supply from the buffer feeding stage ?
Just disregard. I thought this circuit only related to the OPs request for a unity gain buffer with an active gain stage in front that would already have a probably fitting supply.dirkwright said:I don't understand what you mean by "buffer feeding stage"??? This is an independent buffer that I intend to use for hifi.
Harpo said:Just disregard. I thought this circuit only related to the OPs request for a unity gain buffer with an active gain stage in front that would already have a probably fitting supply.dirkwright said:I don't understand what you mean by "buffer feeding stage"??? This is an independent buffer that I intend to use for hifi.
I still don't get your use of two rectifiers (with a more uncommon pinout) when using both positive and negative voltage regulators. A center tapped transformer or using your dual secondaries in a series config only would need one bridge rectifier. Keeping the voltage regulators further apart might save the use of isolation kits if separate maybe needed heatsinks were used for the different potentials at the regulators metal fins.
JohnRoberts said:Can you SIM the voltage regulators? That might actually be useful.
dirkwright said:I'm just really bummed out that I screwed up my circuit board!
Harpo said:something like this little fix without cutting traces or additional wires ..
I've been less lazy than you ; I checked Pass's view on NFB. He concludes that he prefers a low THD stage with no NFB than a high THD stage with a lot of NFB. Doh!JohnRoberts said:I'm too lazy to search out Pass' opinions on this, but what you get from low or no NF is the transfer function of the basic circuit topology without error correction. It is impossible to generalize "no feedback" as having a single sound characteristic. The results will be as variable as number of different topologies available.
abbey road d enfer said:I've been less lazy than you ; I checked Pass's view on NFB. He concludes that he prefers a low THD stage with no NFB than a high THD stage with a lot of NFB. Doh!JohnRoberts said:I'm too lazy to search out Pass' opinions on this, but what you get from low or no NF is the transfer function of the basic circuit topology without error correction. It is impossible to generalize "no feedback" as having a single sound characteristic. The results will be as variable as number of different topologies available.
