Don't worry. That's part of the learning experience, you ask to us old farts and first we sneer, then we explain (sometimes). Hold on! It's gonna be worse (we're getting older and older everyday).
I prefer circuits with inherently low THD, around which I apply some NFB. Feedback is useful when you need defined gain and response.abbey road d enfer said:I checked Pass's view on NFB. He concludes that he prefers a low THD stage with no NFB than a high THD stage with a lot of NFB. Doh!
Well that is just common sense (when one has developed his "common sense" with years of formal AND practical training). Now Mr. Pass putting this on a website doesn't make him a genius - I rather think it makes him a guru.ricardo said:I prefer circuits with inherently low THD, around which I apply some NFB.
It makes sense on low-Z, low-noise, low level circuits. Now on a power amp, this is debatable.It's not NFB that's evil but that you have to use resistors to apply it. Resistors ... well they have been known to resist the flow of electrons. Transistors on the other hand, transist ... 8)
Michael, all successful designs start with a clear definition of what is the aim of the exercise. Arno and others asked some pertinent questions which you haven't quite answered.audiomixer said:One of the things I wanted to know in the beginning was whether there is some opinion on the question are there alternatives to the opamp route.
ricardo said:But to hopefully help your Quixotic quest, I'll recommend
- Avoid the DOAs with LTP i/ps. They are only a poor attempt at NE5534.
- This leaves stuff like the old Neve & Calrec DOAs with single BJT i/p. But even then, their designers would say the same thing as above
- One DOA type, I've had some experience of which DOES have small distortion AND sound goods & different is JLH's Class A power amp topology. Avoid any improvements except by the man himself
Duu.uuh! Was is das?dirkwright said:What I have noticed in my sim's is that the single ended LTP ...
Got some examples?... usually creates a resonance at some really high frequency and feedback often makes it worse. It's a convenient way to apply NFB though.
This applies to all shunt feedback. That's why for most applications, series feedback is quieter.For example, if I apply shunt feedback to the base (or gate) of a common emitter (or source) transistor, noise is increased.
This applies to all feedback using evil resistors.In order to reduce the noise, I try to lower the resistor at the base but then the other feedback resistor is too small for the output stage to drive.
ricardo said:Resistors ... well they have been known to resist the flow of electrons. Transistors on the other hand, transist ... 8)
P.S. I see that you mention an A/D converter. If it is a switched capacitor converter Bruno Putzeys of DSD A/D converter fame (and Hypex switched amps) recommends a 4.5 nF capacitor to ground just prior to the A/D converter so that the capacitors in the A/D converter has something to charge from (as I understand it). I might be able to find a link if you are interested ...
JohnRoberts said:abbey road d enfer said:I've been less lazy than you ; I checked Pass's view on NFB. He concludes that he prefers a low THD stage with no NFB than a high THD stage with a lot of NFB. Doh!JohnRoberts said:I'm too lazy to search out Pass' opinions on this, but what you get from low or no NF is the transfer function of the basic circuit topology without error correction. It is impossible to generalize "no feedback" as having a single sound characteristic. The results will be as variable as number of different topologies available.
Perhaps I should have said I wasn't interested enough.. 8)
The anti-NFB crowd was one of the sundry alternate religious cults kicking around the fringes of audiophillia over the decades. There wasn't any there-there then, still none now.
If it wasn't for negative feedback (invented by a guy named Black early in the 20th century), they would have never made a workable telephone system and many other technologies we take for granted.
audiomixer said:I tested the suggested simple fet buffer, does work kind of, but I had to swap some components, so thats difficult to know if it's near the simulated version, got to swap the input fets to something better and give it another go. nothing that I could really use right now.
Michael
