You should also check results at different tape speeds and machines if you have access to others.
All 3 machines I have (B77, TC399 and TC640) can do 3.75 and 7.5ips. For all machines the flutter bump is there on both speeds. For each speed, the trends between machines are very similar too. Well, some have flutter rollers and some not, while other have better heads and electronics (S/N) and others not... These factors can be easily accounted for.
Also, because the 3 machines might have different W&F specs for different speeds, then I have also checked the following:
- recording 7KHz at 3.75ips and play at 7.5ips.
- recording 14KHz at 7.5ips and play at 3.75ips
(and actually the same dual approach for many more frequencies)
For each frequency, the results were pretty identical with Rec&play made at the same speed.
Funny, the tape choice was also identical: best results with PE41 (old tape) and the rest... are similar but measurably not as good.
Yesterday, I took out the capstan shaft from B77 and today I gave it for measurement (0.3um precision). But the machine is pretty booked and I will have the result only in a few weeks.
If needed, I will be able to grind it with 0.3um precision as well. We will see.
Meantime, some external opinions and
examples will be very useful! If possible. I hope.
