untamedfrontier
Active member
TY! All fixed nowIt doesn't work for me
You must press 'Insert' on the attachment image after uploading the .mp3 file
It sounds very niceHere's a voice only sample, no EQ or other processing, ~8" away, doing my best Wordsushi impression.
Chain was ORS87 > UA Solo/610 (3 gain, 9 Vol) > Apogee One > Logic Pro
I used HL-95, yeah. I'm pretty impressed with the quality of the body, although the fake switches are a little silly.It sounds very nice
chiseled, smooth. Very pleasant voice.
It's not exactly the Neumann sound, in the midrange area, but that's because of the capsule.
What headbasket / body did you use HL-95?
Very flattered... and very flattering! That sounds great on you. The mids in your voice sit very nicely here and your voice is clear, detailed and forward. Mark this one as done. You have yourself a nice little recording tool there that should serve you quite well.Here's a voice only sample, no EQ or other processing, ~8" away, doing my best Wordsushi impression.
I am absolutely convinced that an Arienne k87 capsule will lead you even closer to the original.I used HL-95, yeah. I'm pretty impressed with the quality of the body, although the fake switches are a little silly.
I'll likely try a more premium capsule on a future build (probably an Arienne), but my goal for this first build was to just pass signal, and it does that (and actually sounds pretty good considering I haven't done a bias with a scope). I may also adjust C6, but I'm in no rush to do so yet, as I'm just delighted the mic works.
I was looking at that, but it does not answer my question in a way that I can understand it.
I don't know if it's the same wiring scheme as the Tab T-13, but the wiring guide I've been using for the Ali T-13 is as follows.I think all I need to do is wire this in. Does it matter which side is input or output?
thank you!I don't know if it's the same wiring scheme as the Tab T-13, but the wiring guide I've been using for the Ali T-13 is as follows.
If you turn the transformer so that the text is right side up and the wires are facing downward:
Going from left to right (the first Yellow wire is the one on the left side)
S- yellow
P+ black
S+ yellow
P- black
?? first Yellow to TXI-, First black to TXI+, 2nd yellow to TXO+, 2nd black to TXO- ??thank you!
don't know what the S or P refer to.?? first Yellow to TXI-, First black to TXI+, 2nd yellow to TXO+, 2nd black to TXO- ??
P= primary
S=Secondary
They refer to the 2 windings on the transformer. TXI probably means transformer in i.e connect the primary here. TXO probably means transformer out, connect secondary here.
Think I got it now. Thank you!P= primary
S=Secondary
Can you link to the seller who sent them?I just received these in the mail from Jenny. She must have threw them in with my microphone bodies by mistake. They look to be the same size as a CM-13113. Anybody ever try these.
