OPEN SOURCE DIY Mic Project - ORS 87 - Stripped Down u87
@cello4u
We all started somewhere, without much knowledge. We joke sometimes, but as you already realized, we have good intentions and dedicate part of our precious time and our experience (acquired with efforts, sacrifices, sometimes failures and disappointments, investments, etc., in a life), to help totally selflessly.
The most important thing is to persevere, not to be defeated by problems, failures.
Step by step you will succeed and the satisfaction will be proportional to the difficulties encountered.
Yes, that is in my collection of pictures. Apparently not much help to me.
Assuming that by "that" you mean the PCB view on PCBway... The schematic (with component values, and matching component designators) is right below that, if you scroll down, so... What exactly is the problem, still?
It's me. I'm the problem.
To use it as a reference, clone it, or just use it to have a U87 style microphone?
Mostly to use as a microphone. I have sold recircuited, reskinned transformer less Chinese 87's, and would consider selling them depending on the profit motive.
@Khron , in this case it is about the famous wireless BIAS, which we have all heard of)
(Sorry, couldn't resist)
Thank you. I think I installed the trimpot in the jfet, and then screwed the pooch trying to desolder it (if not before). It seemed to me like it was one or the other (that it would be used in biasing). I thought I read in the thread that the r* was optional, part of the biasing. Guess I was wrong about that. Not sure what part that is in the Mouser BOM. Thanks for pointing these out to me.
R* is only optional if you don't use/remove the trimmer. Likely for most of us, the trimmer is the better option than using a fixed resistor, since biasing can vary a little bit depending on personal taste and parts used in the build.
I don't think there's any reason why you can't just use the trimmer to bias and leave in the circuit permanently, but you'll need to use either the trimmer OR the fixed resistor in R*.
I posted a couple screenshots of my build earlier using the v1.1 board if you need any picture based references.
Hello, can someone tell me why there is a CE mark on the tube mic from Brauner Valvet and not on the Phantoma without tube?
Doesn't it always have to be on the mic if it's a business? and that's good to read?
I think you might want to create a separate thread for that question, that doesn't seem to be related to this topic.
Hey guys, I'm having trouble finding the zener 1N4749A, theres other alternatives there I can use instead? And also I cant find a 25k trimpot, but i have a 20k and a 50k wich is better to use? Thaks a lot!
Yes, virtually any 1/2w / 0.5w zener you can find, between 24v and 33v.
Either one should be fine. Even with a 20k, you shouldn't need to reach the end-stop. But even if you do, just try another JFET (their tolerances are REALLY wide)...
