Hey @JediasHey guys, I made this version of the circuit in stripboard. I'll share here so that anyone can use it.View attachment 131491
We thank you for your work and contribution to the development of our group's knowledge base.
You post a screen shot of the TSC-2 cartridge that clearly shows the front and back wires AND a ground anchored to a face screw of the cartridge while I explained that my cartridges arrived with only front and back wires connected, but ground wires were supplied separately and I'm being a pain for trying to seek clarity on the proper installation... mmmkay.And then @Khron will have to explain to eso one more time what's wrong![]()
Did you read all the previous posts carefully?You post a screen shot of the TSC-2 cartridge that clearly shows the front and back wires AND a ground anchored to a face screw of the cartridge while I explained that my cartridges arrived with only front and back wires connected, but ground wires were supplied separately and I'm being a pain for trying to seek clarity on the proper installation... mmmkay.
That seems like a pretty petty comment.
I have read carefully. One issue here is my assumption that a wire to the body is a ground. I stand corrected. My thinking there is based in larger assemblies where wires to a chassis are typically a ground: mea culpa.Did you read all the previous posts carefully?
The capsule has no ground (GND)
The brass is the BP backplate which does not connect to ground (GND) but to polarization BP.
Connect the blue wire directly to the backplate with a shorter screw.
The white wire connects it to SGNL (signal - gate of jFET)
Absolutely right.I have read carefully. One issue here is my assumption that a wire to the body is a ground. I stand corrected. My thinking there is based in larger assemblies where wires to a chassis are typically a ground: mea culpa.
Regardless of my error in terminology, I received 3 TSC-2 cartridges that each have 2 white wires connected to them: one to the center of each face. There is no Blue wire beyond the additional wires supplied (Which is apparently polarization and can be connected through the mounting screw as I have done, but you seem to prefer a direct connection with a shorter screw). The latest image you've posted again shows a cartridge with different colored wire to each face and a 3rd wire to the BP.
So then the only connections are the white wire of the face I decide to use (SGNL) and the BP (POL) which would be the blue wire: in cardioid configuration the the rear face remains unconnected, or connected to GND.
Is that correct?
eso
Is that correct?
Thank you.Absolutely right.
Great!So I finally got the U87 body. The HL-95 being recommend. Thanks Wordsushi.
It looks and feels solid, with copper inside (didn't expect that?).
From this store: https://www.aliexpress.com/store/1102127808?spm=a2g0o.detail.0.0.1016nmyTnmyTbK
(I removed the black tape on top as it was loose and twisted. But it's easy to replace it I imagine.)
I ordered them direct from JLI Electronics and they're called TSC-2.However, something intrigues me
The capsules you received do not look like TSC-2.
It looks more like an Ali capsule...
https://a.aliexpress.com/_EyPkMAx
Hi Khron, ready for a test etch? I got a M Audio Nova for a stripped down u87 style mic without PAD and HP. I got a Neutrik 10/3 left over from my DIY SELA T12 mics, too. I am ready
I honestly don't know what's going on. I am in Europe and due to the costs I did not order from JLI.I ordered them direct from JLI Electronics and they're called TSC-2.
Maybe a bait and switch?
How about this URL?Great!
But,
The link you posted is invalid (at least for me)
You can already order on PCBWay,Hi Khron, ready for a test etch? I got a M Audio Nova for a stripped down u87 style mic without PAD and HP. I got a Neutrik 10/3 left over from my DIY SELA T12 mics, too. I am ready![]()
Ok, that works.
