I would also think about the possibility of using several pinout types for jFET, in order not to contort the terminals.Ok, this will be the one! Thank you very much @micolas!
So, as a summary:
Ugly coupling pads will remain
- Remove HI-Z traces
- Add ground plane connecting to body using the screws
- Remove redundant/multiple options
- Use WIMA MKS-4 1uf cap
. They do make a difference.
The circuit works with BF, 2N,2SK,J etc.
