OPEN SOURCE DIY Mic Project - ORS 87 - Stripped Down u87
If I may pick a nit, there's nothing to be gained from increasing the signal level and repeating. The bias level which minimises distortion is the same, over a wide range of levels. This post has measurements made with the same ORS87 PCB which illustrates the point.
If you have any half-way decent audio interface, Room EQ Wizard is great free software which gives distortion readings directly, and is much more sensitive than a 'scope. I often use an iPhone with a signal generator app as a signal source, it gives output in the 0-400mV range which is ideal for this application.
If you just want something roughly right, set the voltage on Q1's drain to 10-12V. All the FETs I've measured have an optimum somewhere near this.
By "oscilloscope and/or spectrum analyzer" i meant / implied that their virtual versions should work just as well, be they within REW, or plugins in one's DAW of choice.
That presumes a 24V supply; not necessarily the case in "my" ORS87-plus.
Well, after my 4th or 5th attempt, using the KSA board, I now have a working microphone. I know I'm gonna get kicked for this, but, I cannot seem to understand the directions for biasing...I can see on the scheme that signal injection goes between R15 and R9-but i dont see any connection on the board. Having said that, the mic seems to be very low self noise. The sound quality seems to be good, using a BM800 donor body and capsule. However, I have to crank up the input gain to get decent levels-altho, that may be due to the trashy capsule. If any of you would, please take a listen to the attached sound file for critique. Thanks!
View attachment ORS:KSA.wav
Sounds splendid đź‘Ś Like a U87 actually. I don't know the board, but just stick it in there, stuck it, solder it or whatever is easiest?
U87 is not high gain . S/N ratio sounds alright, can't hear hiss. Sum brum though. Maybe not the mic but something brumming at your place?
Thank you. Yeah, I dont have the best place for sound checks, thats my AC...
I don't see anything on the board that specifies, but, there is a project number W536781AS3P2, from PCBWay
You can compare how your board versus the render currently visible on the project page, surely..?
Or is there a "CAL" wire-pad on the board you have? A photo might help...
It's the 1.0
There we go then - the "calibration" input was not yet physically implemented there. But it can be easily added - desolder the ground end of that 10k resistor (R15 on that board, i guess), and add a 560 or 620 ohm resistor in series with it. The joint between those two is now the "cal" input.
The above-mentioned procedure applies:
Same as every other U87 clone.
Apply 1kHz signal between "Cal" and ground, monitor the output signal on an oscilloscope and/or spectrum analyzer, turn bias for minimum distortion / harmonics, increase input signal, rinse & repeat.
Or you can take a bit of a shortcut too:
Thank you! That’s on me for not realizing there had been an update. My first clue was the cal pad is on the updated schematic, which, I now see, means an updated board…
Thanks much for the clarification!
