AdamFrisen
As this project inspired me to build microphones...
I wanted to replicate U87AI original schematics with capacitance multiplier and 60V for LDC in a separate board (starting with only cardioid).
I used KiCad 8.0.
The boards should fit inside the smaller U87-style body like this one:
https://www.aliexpress.com/item/100....order_list.order_list_main.59.985a1802Qlm5WZ
...and still have enough space for UTM-transformer.
Four capacitors are meant to be soldered on the backside (C1, C8, C9 and C12).
I added an optional NFB capacitor (C13) just the U87 classic has (cause I liked the sound of it when added).
The DC-board using LTC3290, I realized MSOP-10 might be too small to hand solder. OPIC 60V should be easier.
I will replicate U87AI dual DC for LDC and see if that will fit later.
Modifying to get a cardioid version with 60V should be just to remove few connectors for switches and remove some traces.
The big 1uF output polyprop. (MKP1349_1uF_160V) and Bourn trimpot (PV36W) footprints are inside the zip (custom_lib.pretty-folder).
All the footprints are from components I found in Mouser.
I'll post some pictures when I get the PCB from JLCPCB/PCBWay and have them working (or not) and installed inside the mic body.
My intention is to share the U87AI schematics in a complete CAD project which you can modify yourself and order PCB from JLCPCB, PCBWay etc.
I removed silkscreen from the input area, you can bring them back by deleting the components and sync from schematics or some better method in KiCad. These are the three first projects ever I made in KiCad so consider me as a noob learning.
NOTE: XLR 123 is not correct. It should be XLR 231 unless you fix it in the schematics and rewire in PCB layout.
I used KiCad 8.0.
