Brian Roth
Zenith also crossed my mind as well. The wear patterns (if visible) on the R and P heads might yield some clues. At one time, I had a couple of glass blocks I used for checking the tape path of a MCI 2" machine after the capstan motor was replaced. The idea given to me was to go from one surface the tape crossed to the next and see if I could feel any "rocking" of the glass block. IIRC, those MCI's had a number of surfaces the tape crossed. Left to right: input guide, erase head, record head, play head, exit guide and then the capstan.
A crude zenith check method involved "painting" a line of Sharpie on the head where the tape contacted, running some scrap tape over the paint for "x seconds/minutes" and then seeing if the Sharpie ink wore off in a rectangle or a trapezoid shape.
Bri
Bri
