Output transformer advice? Schematic attached.
JW
Portland USA
Hey folks,
I built one of these preamps because I had an Akai M7 mono block around, and this guy Jesse made the schematic available. He was pretty cool and encouraging about it, so I built it, and it sounds really good. It has two bottles, and EF86 and a 12au7. I'm wondering if the 4:1 output transformer is the best choice (?), or if a different ratio might be better? Right now, the non transformer  output sounds a lot better than the 10K:600ohm Carnhill that I have in there. But I like having a 600 ohm out for feeding my diy Pultec etc.
  • 297712d1340567031-tablebeast-modified-akai-roberts-tube-reel-monoblock-amps-bruteforceedit1.jpg
    219.2 KB
Deepdark said:
maybe a lower ratio, like 2K4:600 or something like that
I agree. If you want to drive something approaching a 600 ohm load you should adjust the 12AU7 bias to about 10mA of standing current to give it enough drive capability.
that is a steel core transformer,
if using that 1 uf output cap, there is no DC on the core so you can use a nickel core transformer,
look at the LA2 compressor , the Jensen Ni core 4:1 sounds awesome in that circuit,
Thanks guys.
So, the 220 ohm bias resistor should be changed to 23K? I'm pretty sure I have around the full 230V B+ at the 12au7 there.
So, for 10mA it would be
R=230V/.01A=23K?
The Carnhill transformer (VTB2291) can fabulously conveniently be wired 2K4:600ohm.
Thanks for the recommendation CJ. If I can solve the issue with the transformer I have though, I might just stick with it.
JW said:
Thanks guys.
R=230V/.01A=23K?
The bias resistors are the two 680 ohms ones. Each triode has half the supply voltage across it. Looking at the 12AU7 datasheet I think the present bais point probably about right so it does not need changing.
