nielsk
Working on a later EMT 140s, chasing down a spurious noise I notice that the output transistor pairs are not running at the same temperature. On each side one is running much hotter than the other (uncomfortable to touch), but it is the opposite one on either side. The 2n3053 feeding each pair is running very hot as well.
They all have big heat sinks on them.
This looks to be using an early transistor approach where the B+ is fed to them through the output transformer.
Working on this thing is a real PIA, is there a component (resistor?) I should check or easily tweak to at least get them to run at the same temp without removing everything?
Or maybe a use different transistor? I have found in other devices changing to a BD139 not only sounded better but ran very cool...
