Consul
Has anyone considered taking the "eBow" approach to this problem?
If you use steel for the base metal, due to it being ferromagnetic at room temperature, you can both drive it and pick up signals off of it without anything needing to touch it. Furthermore, reverb times and characteristics could be set by setting up a feedback loop between the pickups and the driver coils and controlling the feedback amount, phase, envelope, etc. Then you could do wacky things like modulate the phase, or run the feedback loop through a tape loop, to get some really interesting stuff happening.
As far as I know, pure gold is not ferromagnetic at room temperature, so a magnetic pickup could never work on it, as a magnetic pickup depends on the pickup magnet turning a steel string (or in this case, a foil) into a magnet so the vibrating string (or foil) will induce a signal in the coil. I agree with Gyraf, then, that if the 240 is using a magnetic pickup to obtain the signal, then the foil can't be pure gold, and the base metal must be ferromagnetic at room temperature. Nickel would work.
EDIT: Oh, hey... It would appear that nickel can be gold-plated just fine, as nickel is the most common substrate metal used when gold-plating other metals. New theory: the EMT240 foil is nickel, with a gold-plating to... I was about to say "resist corrosion", but that wouldn't be necessary with nickel, would it? Perhaps if they were thinking about long-term reliability, they would. Clearly, there are a few factors to think about, still.
