user 65064
Member
- Joined
- Mar 20, 2017
- Messages
- 24
Hi guys, this is my very first thread, please be kind! ;D
I'm asking your advices since I have an old mixing console with mic transformers per channels.
Since I don't use mics inputs at all I decided to try modding their newtork to let it handle hotter signals (in my case line level unbalanced signal).
I decided to go with a padding network and my first attempt was a 10 kohm resistor in series with signal path + a 470 ohm shunt after it, in parallel with the primary winding.
This solution is good for the input impedance but then the signal feeding the transformer was almost killed needing to be followed by an absurd gain stage that would add a lot of noise and nonlinearity..
So i tried experimenting with resistors and a network that let me keep a good secondary signal level is a 1kohm resistor in series with the signal + 220 ohm shunt, in parallel with the primary winding.
The transformer was used to show a 200 ohm input impedance and has a ratio of 1:10 and the secondary is loaded with 47 kohm (but since I use it with an unbalanced connection the ratio should be halved if I'm not wrong).
Anyway I just wanted to know if this route may have sense since in this case my input impedance is quite low respect to normal line level input impedance (in my case is around 1,2 kohm).
I assumed that this wouldn't be a critical load for a modern output stage, isn't it?
I know this padding thing is not good for S/N ratio but it's just for fun and experiment a bit.
By the way, do you thing it could be a better alternative swapping the secondary load, originally 47 kohm, with a 1 Mohm?
If I'm not wrong in this case the primary winding should exibit an impedance of 10 kohm without needing any network, may this be a better choice?
In the latter case, I'm ok to adjust the following preamp stage to avoid clipping since the voltage would be boosted of 5 times (since I use it unbalanced).
I thank you guys and I hope to learn as much as I can, this forum is handsome!
Cheers.
Cheers.
