plumsolly
is it ok to us this pad after the output transformer on a 312 style circuit?
http://www.jlmaudio.com/PAD.gif
I found a few refferences to output attenuators when searching. This post from Bo Hansen was the most helpful thing I could find:
Thanks, Ben
Ok, I avoid this question and instead talk about the normal gain potentiometer, because there are no good way to connect a "output level" control on the 312 card.
There are only one op-amp so you can not isolate a potentiometer between two op-amps, and you can not connect a potentiometer between the 2520 op-amp output and the 2503 output transformer primary because the transformer must have a very low-Z drive.
So the only way to do that is to do a low-Z pad after the transformer secondarys, you can use a stepped balanced constant 600 ohms pad with many stepps that is feed from the all three secondary windings configurated in series.
Or you can use a simple three stepped pad there you can switch between the three secondary windings and get 0, -6 and -9 dB attenuation.
--Bo
Thanks, Ben
