Ricardus
WILL SOLDER FOR FOOD
fripholm said:Yes, attached
The boards are still available. See the first post in this thread or email me at fripholm [AT] gmail [DOT] com for details on how to order.
I will definitely be in touch.
fripholm said:Yes, attached![]()
pstcho said:Hello, guys, is there any help thread about this project ? cant find so far
pstcho said:Alright, thanks for your fast answer
i received all the components this week and build it, as carefull as i could, when i fired up, i got a perfect sound controlled with input and output potentiometers, but no compression whatsoever, also i have all the leds ON, like if the compression was full full all the time, no change in by pass or without sound
any place i should check out where i must have F***ed up ?
pstcho said:if i remove Q3 the sound is great but way too loud ( removed it while the unit was powered, i forgot to close it )
pstcho said:hello, gate is at 0 and stays at 0V ( we talk about Q3 right ? )
qbias voltage varies at c37 till the 2 diodes D1 and D2, at the other side of those diodes there's no more voltage
pstcho said:could be the slam switch that is wrong
pstcho said:yeah i do
when installed i mesure 124K
Colors are Brown Grey Green Gold, 1.8M
Register today and take advantage of membership benefits.
