You welcome. It must be an easy task because as I can see the coils are connected internally and hopefully secondary winding is the top.one. (at least, geniune one has sec. as a top winding). If that's the situation you should just remove the top insulation and there is the CT. Cheers!Hi Moby,
thank you for your good expanation and suggestion!
I will write to FAB about this. If it is an easy hack I iwll try to modify my V8 transformer. If not I will have to live with the decoupling resistors.
Thank you and all the best!
Simon
