I'm always amazed at how your posts are provocative and counter educative.
This thread has turned to s..t.
DF is loss and loss is not fidelity because something's missing. Whether the missing info is perceptible is another issue. Sort of proving a negative. . .Indeed it's interesting, but I have never seen a distinct correlation between DF and distortion.
DF is a very important factor in reliability, though.
Ein. Equivalent Input Noise.
If you want to measure resistor noise, as opposed to the circuits self noise, be my guest.
The electric car was invented over 100 years ago. I'm old but I can't remember back that far.I remember when electric cars had nobody convinced "that there was any merchantable (sellable) benefit".
Can't say that I follow your logic but I vaguely recall grabbing lunches from Micky D's back in the 60s.By the same logic a McD burger is superior to real food, which has few if any "merchantable (sellable) benefit.".
Is that common core math?Fun thing is, getting rid of those caps actually makes commercial sense.
Thor
DF is a catch-all that includes various losses, some linear and other non-linear.DF is loss and loss is not fidelity because something's missing.
I have a problem with this article. See.There was a study on caps like John says in the 80s by Walt Jung and Rich Marsh. Of course it is 45 years old. I'm just posting a link to it but not getting into the fray over it.
https://reliablecapacitors.com/information/picking-capacitors.html
Yes, of course. 10 Ohm would produce an EIN of -142,7 dBuOn I see, a marketing spec not a real world one.
Word. It's one thing not to share a circuit, but quite another to write a dozen long posts begging people to ask about it.I'm always amazed at how your posts are provocative and counter educative.
Actually noise factor would be a better measure
but that also requires a realistic assumption about source impedance rather than the marketing fantasy of zero ohms.
Semiconductor mic pres with 3dB or better noise figures have been around for many years. Any improvement over that, real or imagined, is pointless in the real world.
+1. A shorted input is an unambiguous universal standard that isolates the issue of noise to the DUT alone, which is what we as designers generally want to know.* EIN voltage (and current if necessary) then tell the whole story; it's not marketing at all. 'Noise Figure' is a concept better suited to RF design where source impedance is generally well defined and standardised, and flicker noise rarely contributes.The noise of a system is always that of all noise sources.
By lumping multiple separate noise sources into one, it becomes hard to determine what is what.
except presenting a dead short at the input completely ignores the input noise "current" a significant noise contribution with bipolar transistor input devices.Actually, Ein with input short is best, IMNSHO. Here is why.
We have two separate tests.
Self noise and system noise.
A system noise where electronics do not increase noise would have a noise factor of 0dB and an Ein (0R source) of -oo dBu.
3dB noise factor means the noise of the electronics is the same as the source.
If an improvement beyond that is meaningful or if we may even release our spec to -120dBu Ein (0R source) will depend on the noise of the actual microphone.
Ideally we want to have a noise that significantly ( > 6dB) lower than microphone noise. That is what really matters in the real world.
Let's say I have STC 4104A ribbon Mic, my Z is 30R. Suddenly a Noise factor of 3dB at 150 Ohm seems not so great.
Hence I do not consider noise figure or Ein stated at a specific impedance all that useful.
Two preamp's with similar Ein at 150R can have hugely different noise with our low output, low impedance Ribbon Mic.
Thor
That's why you publish the noise current too, if it is significant.except presenting a dead short at the input completely ignores the input noise "current" a significant noise contribution with bipolar transistor input devices.
Using NF includes all these sundry sources into one consolidated measurement.That's why you publish the noise current too, if it is significant.
Exactly, which is confusing since you can't extrapolate it to any other source impedance, you're stuck with whatever the publisher chose. Fine for RF where everything is always 50 ohms or whatever.Using NF includes all these sundry sources into one consolidated measurement.
Low z audio mics are nominally 150-200 Ohm source impedance so NF wrt 150-200 ohm should be representative and easier to understand*** than ein noise voltage in dBu without bandwidth or other supporting details. Sadly the consumers will take dBu numbers and try to compare different companies SKUs without the rest of the story needed to make those comparison apples to apples.Exactly, which is confusing since you can't extrapolate it to any other source impedance, you're stuck with whatever the publisher chose. Fine for RF where everything is always 50 ohms or whatever.
BUT.... a mic pre without input and output transformers is like a vegan meal....it won't satisfy
