Rob Flinn
Actual current draw is more like 100mA as Winston says.
Spencerleehorton said:Yes originally thought 100ma per channel but then looked in another thread and it said 500ma?
Would be good to know, I might test mine
Rob Flinn said:Actual current draw is more like 100mA as Winston says.
I've tried to figure out but I couldn't find any spec regarding current draw and the schemo is not much help in that regard. The OT has a ratio of 1:1.7. In order to deliver +26dBu into 600r, this computes to about 80mA peak at the primary, so the idle current in the 2N3055 must be about 100mA. I would take a margin for the other stages.Winston O'Boogie said:Surely this is a typo yes? I can't see how a Neve pre amp circuit would be more than around 90 -100mA, most of that being the single-ended class A output transistor.
abbey road d enfer said:I've tried to figure out but I couldn't find any spec regarding current draw and the schemo is not much help in that regard.
It could work somewhat but I wouldn't recommend that. As I said earlier, the two PSU's should be separate as much as can be.Spencerleehorton said:I have a 2 x 24v toroidal txf, could i then take a feed off one 24vAC winding for the 24vDC supply and use both windings for the 48v supply?
That's what I would do. What power rating is your toroidal? For best performance I would use two identical xfmrs, although one would be very lightly load, I would mount them humbucking, so their magnetizing fields cancel.or would I need to have two separate toroidals?
This has been mentioned several posts ago. This should be taken care of by changing teh adjustment resistor to 82r instead of 240.mhelin said:Doesn't TL783 require min. 15 mA load? That should be taken care somehow.
yes, or draw about 10mA to a load.Spencerleehorton said:well i've swapped out the blown LM317 and put in the 783 and i'm getting 60v with 220R to output and 8.2k resistor to gnd.
so do i need to change 220R to 82R? and the 8.2k to 2.7k?
With 82R current setting resistor, a voltage setting 2K7 to gnd will give you about 43VDC out. Depending on parts tolerances (FI TL783 Vref 1.2 ... 1.3V with typical Vref 1.27V), you'll need about 3K to gnd for 48VDC out. A 500R trimmer in series to your 2K7 for a 2K7... 3K2 range to gnd will catch these tolerances for the wanted 48VDC output voltage. Just keep an eye on power dissipation for these shunt arm resistors.Spencerleehorton said:well i've swapped out the blown LM317 and put in the 783 and i'm getting 60v with 220R to output and 8.2k resistor to gnd.
