[quote author="Svart"]ok, I suppose the easiest way to explain is compensating for the latency of the system of amp-speaker-air-mic VS. a DI box to align the DI and the mic in time, not just at certain freqs.[/quote]
If trying to compensate for an air path length transit time, vs. electrical transit time the problem is pure time delay.
In digital domain it should be no big deal to add some delay offset to the direct channel to line them up with the later arrival.
To make a free standing (digital) delay purely for that purpose is probably a little harder and more costly (than phase shift), but not out of the question for this group.
FWIW, if the air path is short (a foot or so) the time delay is well within Haas fusion region and transient events will be fused together as one, while the wavelengths where cancellations can occur only affect higher frequencies. Longer air path lengths will drop the frequency lower where cancellations can occur.
Different mic placement is cheaper than adding delay compensation.
