thomasdf
Hello
For a project where I am toying with the idea of using a phono cartridge as a contact microphone, I'm looking for a good quality phono preamp design without RIAA correction.
From what I understand, without RIAA a phono preamp is just a simple line preamp with a high input impedance. Is this true ? If the Audio Technica cartridge I want to use is said to have a 3K output impedance, what the proper way of building an appropriate preamp ? I think I'd use only the "side" part of the cartridge to amplify the vertical movement rather than the side, but I'll have to experiment with this too.
I was thinking of using a 12AT7, straight to the grid... I've found schematics... but for heat and power supply reasons I think it's better to go with IC / semi conductors.
Thomas
Thomas
