Hi, I have this desktop DSP synth from Use Audio that uses the technology from the Creamware synths (Minimax,Prodyssey etc).
The problem is that unless the USB cable is plugged in and connected to the PC it has this horrible ground loop hum on the outputs.
I'm wondering if it is possible to resolve this by grounding it in some way.
Also the outputs are unbalanced, do you think it's possible to convert these to balanced outputs?
Any help would be much appreciated
