The Odd Coil
New member
I had a few problems with the module going into high-freq oscillation when the treble control is turned to + boost.
You will hear it "Pop on" if so.
Otherwise it is just noise in the circuit that is being amplified by the treble boost. Shielding will not reduce/increase hiss that much. One transistor, if it is off value and the idle current is high, will make hiss. You can make a sound sniffer by a probe with a DC blocking cap into some amp and speak. then trace throung a module/circuit beg to end and you will find where the hiss starts.
Have the hiss making circuit on, but listen to it through a probe into another amp/speaker...
