pacorro said:ah, ok, I saw your freq response graphs and are similar to mine, so it's the natural response of the Eq and not a problem in my device.
Sorry![]()
In a simple passive EQ like this one, the steepest rate of cut/boost is 6dB per octave which is the same as 20dB per decade. This means if you want 20dB of boost or cut at 10KHz then you have to start boosting/cutting close to a decade below which is why it starts at around 5KHz. The same arguments apply to the low boost cut which is why the 20Hz curt starts at around 150Hz. If you look on line you wll find curves for the original Pultec EQ and they are very similar.
Regarding the log pot for the bass cut, again this is the same as used by the Pultec. However, if you load the output of the EQ with anything less than about 470K you do get more cut at the 100% setting so the last 25% does seem rather crowded. The bass cut always flattens out eventually so it is not a true high pass filter. I think you are seeing the combination of the bass cut and the roll off already present in your circuit.
