funkymonksf said:
I'm having a hard time understanding the psu pcb for the tube gain stage. Now I understand the bom list Ian offered in the first post, but I am unsure where the connections are on the pcb, as in where do I connect the psu to the tube pcb? Is it the 75v that is b+ and the heater is heater and the unmarked square is the ground?
Sorry, this is my fault. I did not use a consistent annotation thoughout. You need to tie up the:
tube gain make up stage circuit diagram
http://www.ianbell.ukfsn.org/pics/PMTGMsm.jpeg
with the system diagram
http://www.ianbell.ukfsn.org/pics/EQSystem.png
and the PCB as follows:
Point A on the circuit corresponds to point A on the system diagram and to pad Pout on the PCB
Point B on the circuit corresponds to point B on the system diagram and to pad Pin on the PCB
Pad PG on the PCB is the local ground connection for Pin and Pout and should be used for the screens of the cables going from Pin and Pout to the EQ bypass switch.
Point C on the circuit corresponds to point C on the system diagram and to pad In on the PCB
Pad 1G on the PCB is the local ground connection for the screened cable that connect Pad In to the EQ bypass switch and then on to the output of the equaliser itself.
The HT+ on the circuit diagram connects directly to the HT pad on the PCB
The connections labelled heaters connect directly to the pads labelled H1 and H2 on the PCB.
The Pad labelled ** on the PCB is the tube gain make up start earth point and should be connected directly to the 0V of the power supply as shown on the circuit diagram.
Hope that clears things up a bit.
ALSO..what are people in north America using for psu transformers? If i am correct we need a 120ac to 250vac 25ma & 6.3vac 1.2a? If I found a tranny with higher amps is that okay or will I need to modify my values.? Anyone?
Thank you,
Brice
Higher output amps is OK, the circuit will just take what is needs and no more.
As to what to use in the US I am sure someone asked this before and they found a reasonably priced toroidal transformer that would be ideal for the job but at the moment I cannot remeber the make.
