chrispbass
Nice job Holger, have you fitted a bypass on each channel?
Chris
Chris
Yes, utilising the Dingo relay bypass.chrispbass said:Nice job Holger, have you fitted a bypass on each channel?
Chris
e.oelberg said:How much makup gain do you need for that EQ ?
thanks, Nicholas
mus1k_freak said:if anyones interested here's a link to my mouser cart for this build, i had to use 5k, 50k and 500k pots instead of the 4.7k 47k and 470k, otherwise i kept everything else the same just to keep it simple. nothing in the cart for the tube make up stage just the eq with bypass switch http://www.mouser.com:80/ProjectManager/ProjectDetail.aspx?AccessID=cbfa3d750d
erikb1971 said:Hi Ian
Iam sourting for the gain make up stage now, and what are:
preset pot VR2 1K Lin
preset pot VR1 470K Lin
erikb1971 said:Am I looking for ac or dc? I am a bit spooked with all the stories about danger with tubes....
erikb1971 said:so that could be something like this, even though it does not state lineair?
http://www.reichelt.de/Miniaturtrimmer/75H-1-0K/index.html?;ACTION=3;LA=2;ARTICLE=3475;GROUPID=3131;artnr=75H+1%2C0K;SID=12Twg8738AAAIAAFK8aRgffe5c225175f44e6d02d3f5e3cb32f64
Yes, 400V dc is what you need.and for these:
fixed 100nF 100nF 400V Polyester
fixed 2.2uF 2.2uF 400V Polyester
edit: I am guessing DC, since AC is stated seperately elsewhere on the xls file.
erikb1971 said:clear, thank you!
And what about the properties / values of the boost / cut pots in the poshmen's? (the two different mid ranges with one boost / cut pot per band with on off on switch)
