that schemo I posted is a dud... the pots do nothing, and those who have built it say it just brings the level down a ton, with no actual compression
It sure is a lossy loser if loaded with typical modern 10K inputs..... it is a 470K pass-through with a 5Meg-60K shunt. Basic circuit principles. Dunno why you can't get it to work in sim where loads are typically infinite. Yes, the sidechain is ugly. And some sim tube models don't model the grid diode.
PRR's vari mu has semiconductors in the side chain not the signal path.
I recall a blameless IC to bring up the level and drive modern low-Z loads. If you insist that sound never touch silicon, replacement should be obvious. If you also ask that it drive any box in the studio, it will be hot and costly.
a high slope vari mu pentode which might well make it more suitable
Secret tip: you generally want LOW slope. What you generally want is high current for the Gm you get. An un-thrifty amplifier. You want large input swings yet still have plenty of output current left in deep GR.
circuit I posted did not specify a tube type
However that circuit is heavy-NFB. Hi-NFB suggests a high-slope valve. However there is so much NFB, and any likely pentode has so much gain, that it may not be at all critical (A Good Thing).
why he used a 12AU7 as a vari-mu
It generally does NOT matter a lot what tube you use. All tubes reduce gain as current is reduced. Generally along Child's Law, except with exponent of 1.2 to 1.4 (Child showed 3/2 or 1.5 for ideal geometry). The "Super Control" (6BA6 and kin) tubes deviate below -20dB, but at this point their plate current is so very-very small that we can't get decent output in audio loads (RF/IF loads are different; ponder).
12AU7 is hot-rodded from 6SN7 and a whole family of General Purpose Triodes. The things they did to spiff-up the high-current gain actually reduce the low-current gain. The deviation from Child's is significant in the first 20db GR; moreso than most other tubes people insist on sticking in.
When people try this or that other tube, not just for sexy/fad/copycat reason, they are probably not driving the sidechain well and mis-matching the tube to suit the sidechain.
the cross coupled 6BA6's somehow cancel out the thump
A more-readable image with part values:
GE Ham News Volume 13, Number 6 page 6 (700KB PDF file)
It is Current-Steering. A topology better used with fixed input level and output turnable down to zero (was a VERY popular volume control for TV chips).
In a pentode, cathode current is just about K, G1, and G2. The division of plate and G2 current is (simplified) mostly about G3 voltage. Put audio in at K-G1 and the electron stream flows up past G2. Dinking G3 passes the stream to plate or steers it to G2. The sum of P and G2 current is nearly constant.
So as a simple plate-loaded amp, it would GR and thump.
Add a second matched pentode to the same loads with P and G2 swopped. As P(V1) current drops, G2(V2) current rises. Total load current is near constant. Thump tends to cancel.
wonder if a long tailed pair could replace his output transformer
You said it yourself:
The dc shift at the plate is very large - almost the entire supply range.
Devise a long-tail with rail-to-rail common-mode range. Don't reduce the voltage across the GR tube: the max input level (and therefore the S/N ratio) is roughly proportional to that voltage. Possible approaches would include a stiff tail (a pentode) and a second even higher rail for the longtail.
There is a cheap trick possible. If you set the bias and coupling well, the longtail will clip the initial transients that the sidechain is too slow to react for. Short neat clipping is inaudible, certainly preferable to gross overload in filmsound or disk-cutting or broadcast license citations, and the sidechain can be much cheaper.
which would save a lot of money.
$17?
Ian, run all the variations. Cheap hi-THD thumpers and over-complicated mish-moshes. I don't think there are any tricks un-tried (there certainly are a LOT of tricks tried). You may find that a twin-triode VCA can do studio-quality work as well as any.
