Apologies in advance for posting another basic question, I'm sure you good people don't mind (too much)...
Something I just can't get my head round... When inserting a level pot into a circuit between two op-amp sections, in this case a buffer and an inverting mix stage, how is the impedance affected? Does the source see the pot resistance (which I gather is actually the parallel R of the pot setting and the remaining R shunted to ground..e.g. 100K pot at 25%=18.75K) as part of the input resistance of the following stage..i.e. This value+series resistance of the mix resistor. OR, is the pot value seen by the mix input in series with thge source output R?
I'd be much happier understanding this rather than making arbitrary choices based on what I see in other circuits (which, by the way, seems to be totaslly inconsistent!?!).. I want to know how the pot affects my mix resistor value, and how to balance the impedance from source to pot to input correctly. Simple stuff to most of you I know, so simple that most reference material goes right over my head..Sorry!
