Is it safe to assume that the noise radiated from tube equipment power transformers is mainly from the heater winding since it normally has much higher current ratings compared to the HT ?
For tubes with series / parallel heater option like the 12A_7 series does it make sense to use the 12.6V option whenever possible since it has half the current requirement ?
I guess the power transformer should radiate less noise with a lower current and also be of smaller size but I am wondering if the 6.3V option has an advantage in terms of less noise coupling into audio because of the lower voltage ?
Probably the noise creeping in the HT from the heater winding should be taken in consideration as well, is that in some way related to the voltage of the heater winding ?
