Mihobro
Member
Capacitors and transformers have some very interesting frequency dependent characteristics especially at the high and low extremes. Phase shifting, harmonic reactance and other distortion too. And since even a plain wire can have capacitance and reactive elements, we may not be able to measure it but it is still going to be there. We used to spend a lot of time overdriving circuits with sine waves at different frequencies, and also response to square waves to measure slewing rates. The hope is to exceed the ability of the hearer, which varies a lot also according to ear structure, and ability of the brain to process audio etc. We are fortunate to live in a time where components have improved a lot,. For example, new "music" caps are so much better than the ones from days past. I have found recapping old tuners from the 70's with modern caps, can be like night and day. Also the oversizing of caps, in signal pass circuits an octave below the originals can help to really open up the bottom end.
On another note: RF filtering requirements vary from location to location. I lived down the street from the Empire State Building's transmitters and had all kind of RF bleed into a Neve console from stock Neumann, Audio Technica and to a lesser degree AKG mics. oddly enough and counterintuitively, they responded to the removal of the small silver and ceramic caps across each of the legs of the mic outputs and the ground, what I guess is a RF shunt in theory. sometimes filters setup a better antenna. Of course, just down the block and in the studios that had chickewire faraday shields built into the walls, these mics had no problem with RF. As far as preamps are concerned, most mixers being being manufacturered today use similar two stage discrete fet design and sound better than most of the famous console mic preamps with the exception of Avalons, Jensens and a few other legends, largely because of improved components and computer aided designs. If you are not ready to spend a fortune though, the latest preamps like Mackie VLZ4 and others, may work for you. Keep on trying new stuff, We all may eventually get to recording something meaningful..eventually.
