dirty1_1garry
This thread dedicated to the PREDI’CT project - tube preamp for instrument signals.
This project originally was born from these thread:
http://groupdiy.com/index.php?topic=50529.0
Feel free to ask and comment!
22.02.16 update: !!! The project is frozen for an indefinite period until a there will be no budget for its renewal
Check Reply #76
So what’s that?
This is a pcb project that provides a simple way to convert an instrument signal to line level while adding warmth and character to the sound. It amplifies the signal with a tube-driven amplifier based on one 6DJ8 type tube directly into a transformer that converts it to a line level signal with a 600 Ohm load output.
With an input impedance of 1 MOhm, it provides about 18dB of gain, and a harmonically rich tone to the sound. It perfectly suits any kind of guitar pickups, adds richness to analog synthesizers, and enhances the character of any electrified instrument that is run through it. A great choice for bass guitar thanks to it's full low end!
This project allows for different variations based on your own taste.
Build aspects
Pcb contain signal chain, B+ power supply and voltage regulated heater supply.
For building ready for use standalone unit it’s also necessary external components:
output transformer, power transformer, jack connector, output XLR male, iec power plug, output pot, power indicator lamp (optional). Project doesn’t contain rare components.
Output transformer options
there are few options like edcor GXSE5 or my custom C-core transformers specially made for this project.
Power transformer options
I test unit with 200V B+ voltage. But 200V not so common voltage for popular transformers.
I think that it’s possible to use power transformer with another value of secondary voltage, like 220V. It’s more common and simply to find. Will check this in future (unchecked yet).
At an early date I could offer proper custom power transformer with 110/220 input voltage.
Here is a places where it's possible to buy such trans:
http://www.toroidal-transformer.com/shop/high-end-audio/power-transformers/314/2n465-powertransformer-for-tube-amps---44va-.html#.VHgUQdymibB
Documentation and information
https://yadi.sk/d/HT3DvLO5dQzbB
Mouser carts
onboard:
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=e6494d3200
outboard:
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=6e1153d667
Case options
I think that it’s pretty comfortable to pack one channel into instrument case with appropriate sizes. Or it’s possible to pack it into 2U case. It’s possible to pack two unit’s into 2U case.
BUT! Very important! Power and output transformers should not be too close too each others! Otherwise it’s possible to get noise and hum.
At an early date I could offer examples of front panels for 2U cases. Also I will have 2U front panels for sale.
____________________________
UPDATES:
BOM edited - R7 = 39K, R8-R10 = 2K
no R11 on pcb - my mistake
27.03.2015 ALL TRANSFORMER KIT'S SOLDOUT. WAITING A NEW BATCH OF TRASFORMERS!
suitable 2U chip case:
http://www.parts-express.com/middle-atlantic-ec2-economy-rack-chassis-2u--262-442
Here is an example of fully assembled pcb:
Regards,
Check Reply #76
So what’s that?
Build aspects
Mouser carts
onboard:
outboard:
Case options
UPDATES:
Regards,
