mrtnasty
Hi, have 60hz hum in my recording setup, and I am suspecting it is due to ground loops. I have a preamp and compressor that have their chassis grounded to earth, and also both have both input and output xlr pin 1 grounded to the chassis. If I remove the grounds on xlr pin 1 from both outputs, is that the proper way to break the ground loops in my setup? Also somewhat related, my microphone does not have xlr pin 1 connected to the mic body, should I make that connection? Thanks.
