buschfsu
guys im using a 1 milliamp jewel meter for my varimu. it barely causes my meter to move (.05ma) when on. on should be full cathode current. any advice other than adjusting the trimmer (its wide open)?
PRR said:> so 0.09v=.9mA(100r)
Should be more?
yes it sounds f$%#%!ing greatPRR said:> so 0.09v=.9mA(100r)
I estimated typical 6mA for 12AU7 at 100V supply; is that the tube and supply you are using?
But that's not a big problem.
Does sound go through? Does it squash?
> 1mA analog meter ... barely a twitch.
> led in the psu ... meter was .75mA.
Incredibly odd. (Is the LED current really as low as 0.75mA? 7mA would be more typical; I'm wondering if you got a mis-marked 10mA meter?)
I assume you tried both ways; that it isn't just slamming the pin trying to go "below zero". The terminals should be marked, but mistakes happen. However the pin is usually a bit left of the zero, so you'd notice it trying to go the wrong way.
> does the ohmage listed for this meter in the mouser catalog mean anything? (it says 1.1k)
Yes, and I'd expect more like 100-200 ohms on a 1mA movement. In this case 1K in the cathodes "matters". I'd still expect it to "work": show a clear indication when idle and dip when flogged.
