Hi @LevinGuitar ! I just got a Studio Project TB1 for a very good price because it was sold without a PSU. This is not a problem since I will build a new one. I found a schematic that says 200v for B+
I'd like to ask you please if you know the plate current ? with Ra 100KΩ and Rk 3KΩ it must be around 1,5mA... ?
BTW I don't understand why such a power dissipation for R2 100KΩ (5w? 3w?) in the mic ? (1,5mA^2)*100KΩ = 225mW... I see brown-black-black-orange on the pict attached so 100KΩ
Same with the 2 zeners 100v to set HV out : they need more than 1,5mA to be active and this 1MΩ load does nothing about it... so the tube current must be higher than 1,5mA ?
I intend to do some mods :
- set heater voltage to 12,6v DC and elevate it with a divider from HV (+ 25v on ground ref.) > I will use the one unused wire of the seven for the "minus elevated"
- change the capas' where improving quality is needed
- change all resistors for metal
- regulate HV and add a switch to turn it on/off
- regulate heater > I don't understand either why heat is set to 6,3v DC
Regards
Regards
