Hi y’all… long story short, I’m making a simple mic preamp with his own PSU, putting down hold fashion with a breadboard, and my eyes are crossing already
Everything good so far, but is never late for rookie mistakes.
I stuck on the psu. A +-16v and 48v power supplies, schematics are reliable. Using LM317 for positive and LM337 for negative.
I got it to work. +16 good, +48good, but -16 had a problem. The DMM stuck on -25v and adjusting the trimpot won’t make any difference.
After a quick analysis I realized I put the same Vin and Vout on the 337 like if was the 337 (dho), so I simply desolder the trace and routed in the correct way. Full of hope I turn it on, measure the output voltage. +16 good, +48 good, -25v: trying to adjust the trimpot and nothing change again.
I checked several times if tte adjust section is correct and yes it should be fine.
The only thing jump in my mind is if the 337 now is bad. But still regulate the voltage well!
Anyone went trough similar steps?
Thanks in advance
Thanks in advance
