PSU tube preamplifier.
vmanj
Greetings to all.
In my tube preamp, the anode voltage is made according to the diagram (in the image).
I have a question, which connection option (A or B) for the output capacitor will be correct?
B
Edit: The MPSA42 has rather a low gain for this application. Its hFE at 10mA collector current is just 40. So if your load draws 10mA you will nee to provided 10/40 = 0.25mA of base current. This has to flow through the 330K resistor so it will drop 330 * 0.25 = 82.5 volts and your HT voltage will drop by the same amount.
Thanks, I'll clarify a little.
Two 12AX7 tube, current consumption is about 5 mA.
Which option is better to choose for connecting the output capacitor (1 µF) for this application A or B?
Once again, we have a "capacitance multiplier" design. That poor little MPSA42 will quickly die in the real world.
Bri
I think these virtual battery power supplies are hilarious. Considering most of these are created this way because they don't know how to cancel things out or avoid them entirely. I like making springy simple CLC power supplies that sag and spring because it gives mic preamps and processing gear an interesting dynamic expansion effect.
I would do something like a CLC with two 2.2 uf and a 15H coil and run AC heaters correctly.
Oh yea other important thing is running a 6X4 tube because solid state power supplies are not that great with tube gear.
