Bo Deadly
Morls,
As you can see from the numerous posts, the heater traces on those boards are quite simply wrong. If you have any more Drip boards you should probably drip them into the trash can.
But you can salvage this build I think. For now maybe keep it simple and just add heater wires like in your modified pic. But if you're paying attention the critical bit is that you want to minimize the space between the two wires. Meaning no "loops". Loops of opposing currents emit electromagnetic radiation. This is the problem with the PCB traces on that board and it is almost certainly the source of most of the noise. You can see how the two different heater traces have a big gap that make the current run around in a big loop.
So the simplest fix would be to do something like this:
![1623947324488.png 1623947324488.png](https://cdn.imagearchive.com/groupdiy/data/attachments/33/33911-ab203ed0607fcb8d9c6d10f17f97025a.jpg)
So this is looking at the edge / bottom of the PCB. Make one long section if tightly twisted wires using heavy gauge wire like 20 AWG. Note that the overall length is going to shrink quite a bit if you use a drill to twist as described above so use more wire than you need.
About 6" from one end tease apart the twist enough to create a gap in the insulation with an Xacto knife taking care not to break any of the conductor strands. Pull the insulation off about 1" (I suppose you'll need to un-twist the end temporarily to just pull the insulation away to create the gap and then twist them back together again after) and then put a sharp bend in the bare gap. Solder those bare gaps to the heaters of one of the two tubes with the wires coming away from the board at 90 degrees. Don't lay them flat across other traces. Then bend the short end back up to the other tube, trim and strip the ends accordingly and solder those heater wires. Make sure you use the same wire from pins 4,5 and the same wire for pins 9. So now you have a loop of twisted wire sticking out about 2-3" out from the PCB. Then trim and strip the other end to solder directly to the rectifier tube socket pins but leave enough slack so that the heater wires can come down away from the board at 90 degrees and rest along the bottom of the chassis. You wan the heater wires to actually lay flat along the bottom of the chassis if possible because the steel will actually "absorb" some of the electromagnetic radiation so leave a decent about of wire between.
Then cut the traces after the lamp terminal block like in your modified pic.
