I have build two pultec eq’s ptp with rainton’s chassis and layout.
They worked very well and measured surprisingly quiet for tube eq’s.
Now one of the two is faulty. It works well and after a minute or two it shuts down. There a loud static and everything is distorted. When the eq is bypassed.
I have switched the 6x4 with no luck.
The voltage rails are within spec when turned on until a few minutes after the 345v drops to 338v, 290v to 274 and 250v to 263v. I’m a bit scared to switch the other tubes because I bought really decent ones...
Edit: the voltages rails in the other, working, unit stay within spec.
