buschfsu
ok so ive read the posts about setting up the amveco 62082 even though they contradict. one post says to run the transformer 2 primary in series the other says parallel. and a third says run both in series on tx 2?????
my problem is this. when i wire in series i get 330V dc at 3.3K 2w resistor and it glows red hot.
when i wire in parallel i get 165v and it gets pretty dam hot also. i get about 19v on the tube side of the 3.3k resistor. transformer 1 is doing its job 6.1v out of the regulator and about 14.9 v out of the primary.
anyone have any idea what could be wrong?
http://www.groupdiy.com/index.php?t...ostorder=asc&highlight=amveco+pultec&start=15
first post shows parallel, second post describes serial????
