Pultec Solid State Gain Stage (LANGish) Documents Updated
ForthMonkey said:
There is RGAIN.I want to get gain about 20-30dB.
If your circuit is still the one you posted earlier, you need the trimpot (unlabelled) to be about 15k for 30 dB gain. The way it is arranged the minimum gain is unity (0dB). If you want a better control range, e.g. 20-30 dB you make the trimmer 5k and put a 10k resistor in series. I think you should read about the gain formulae for the commonly used implementations of opamps. In that case: G= Rfb/R1
In that case it won't affect your output impedance unless you go close to the open loop gain, when the OL output impedance of the opamp will start to take place... So, not, it does not affect the output impedance.
JS
ForthMonkey said:
I added final circuit to first post for now.What do you think?
The input gain is now -6dB. The actual gain range of the output stage is 27 to 32dB. Is it what you want?
R3 is not connected properly. It should be in series with C9; it is now in parallels. also there should be another 470uF in series with R2.
You should make provision for a small cap across R6, for the risk of oscillation.
Finally, I don't see any decoupling caps on the schemo; don't you intend to add them?
Yes,it's what i want.I will use this with passive EQs.But i have to change RGAIN to 22K and R10 to 5K.I want a little bit wide gain range.
I've used API Line Amp circuit.
http://danalexanderaudio.com/ApiInfo/api2520_02.jpg
Yes,i will add 10-47p cap.
I will add them,too.For now this circuit final design but without improvements.
I'll add circuit.
I added two circuit.First one is simple with impedance balancing.Added all parts.
And transformer balanced version with 2520 I/O & 2503 out transformer.
Can you check two circuits? And tell me 2503 pinout for 600 ohm.
