"commonly held beliefs"
Came in Morgan Jones. Since the publication of his comparative test on harmonic distortion the tube is condemned.
Let it be clear, the winning 6SN7 is a superior tube. Evenly spaced lines in the graphs. Low distortion at all operation points.
Morgan Jones tested all tubes at 8mA anode current, same high tension.
It seems logical and fair to test all tubes under the same conditions... Well, it is not. Unfortunately he had not the idea for an extra test to compare tubes at an optimal operation point for each tube. He jumped to conclusions.
Conclusion about the ecc82/12au7 tube:
"Later generation valves such as the ECC82 (also intended for use as a field scan oscillator) benefited from improved production techniques and distortion is extremely consistent from sample to sample; it is consistently poor."
It is tempting to change it in:
... were consistently tested at an inappropriate operation point...
also:
"The results in Table 3.1 speak for themselves. All of the alternatives are inferior to the 6SN7GT/12SN7GT and produce significantly more H3. The Loctal 7AF7 dual triode and B9A ECC82 dual triode are particularly ghastly."
- Morgan Jones' test: H3 distortion of the ecc82 is 29dB higher than the distortion of 6sn7.
- In my preamp:
6sn7: H3 is approximately -85 dBu at all operation points. An amazing result!
ecc82/12au7 at the best operation point: H3 is below -100dBu in all cases. The ecc82/12au7 tubes are indeed very consistent.
All forums adopted Morgan Jones' conclusions and the 'commonly held belief' of the ecc82/12au7 being horrible was installed.
On this forum:
"... 6SN7 and friends beats the pant off the 12AU7 for distortion..."
"...the Russian 6N1P and that is almost as bad as the 12AU7..."
"... Definitely not a 12AU7... a tube with the worst ever intrinsic distortion..."
etcetera...
In this thread I got a friendly suggestion to consider a better tube in post #49.
For the second build I am faced with the dilemma: Use the 6sl7/6sn7 octal combination - go for a more 'vintage feel' - as was the first intention, or go for the lowest possible distortion (inaudible difference) and continue with ecc83 and ecc82/12au7 ???
Paul
During decades people happily used the ecc82/12au7 tubes.Interesting, this contradicts commonly held beliefs about 6SN7 versus 12AU7. Most in fact seem to think of 12AU7 as horribly distorted.
also:
- In my preamp:
On this forum:
etcetera...
Paul
