Ego Tripper
So I'm trying to build a power supply for my Soundcraft Ghost by using two Power One HE24-7.2-A linear power supplies for the positive & negative rails. My first attempt at wiring them into the same enclosure ended in a bang (literally) when I forgot to tie their 0V to chassis ground. So I replaced the fried power transformer in the positive rail and ended up replacing the other PSU since a wire arced to one of the diode pairs while un-mounting it. I started mounting and wiring the new/fixed power supplies in the master chassis, this time with fuse holders installed. So I figured that I'd just double check that the (rearmost,) negative supply was working fine before I mounted and wired the positive supply. Unfortunately, the PSU won't "go negative" with it's positive output tied to chassis ground. The output hovered near ground and the unit produced a disconcerting hum. So I disconnected the positive-to-ground wire (the only output that was connected to anything (aside from my scope)), and ran the power supply as a regular single-ended positive supply & it worked fine, not even humming like earlier. I used a continuity tester to ensure that the power supplies' negative output is not grounded to their chassis, and they're not, so that rules out the most obvious possibility.
So my question then, is whether this is normal or not, i.e. do both power supplies need to be connected in series before the negative supply will "go negative"? Obviously, I could test this theory by simply mounting and wiring the second power supply into the master chassis as the positive rail, but I've already fried enough of these power supplies and I'd prefer not to ruin any more if that experiment were to fail. Or maybe it's something else entirely-- your input is appreciated.
