I thought this might be interesting (PDF page 55)
https://ia902300.us.archive.org/24/...smpte-motion-imaging-journal_1952-02_58_2.pdf
This excellent performance is attributable to a unique
circuit design wherein the automatic-gain-control voltage
is a function of the input signal voltage, rather than
of the output signal voltage. The control-voltage gen.-
erating section of the amplifier incorporates large powertype
amplifier and rectifier tubes in low-impedance circuit
arrangements, resulting in extremely fast develop
ment of the automatic control voltage. Another major
factor contributing to the exceptional performance
shown in Fig. 7(a) is the use of a special time-delay network
in the signal channel just ahead of the point where
gain reduction takes place. This network acts to delay
the signal by approximately 80 microseconds, and the
gain is already reduced by the required amount upon
the arrival of the peak at the point where gain control
is efected. A close examination of Fig. 7(a) will reveal
that automatic gain reduction occurs near the point q
in time, whereas the 14-db peak does not arrive until a
!apt- time at point p.
The 10,000-cycle performance shown by Fig. 7(b)
again ilustrates the extremely short efective attack
time of the amplifier. Even at 10,000 cycles, the 14-db
peak which arrives at the point p in time is efectively
prevented from exceeding the maximum steady-state
value. Fig. 7(b) indicates excessive gain reduction (overcontrol)
for the first cycle after the arrival of the peak.
Over-control which persists for so short a time as shown
in Fig. 7(3) (approximately 100 microseconds) cannot
be perceived by a listening test, and is certainly preferable
to under-control, since it renders overmodulation of
subsequent equipment impossible.
It can be observed from Fig. 7 that the "thump" component
of the amplifier is of very small amplitude, an
additional design feature of this unit.
The amplifier described above was developed by E.
E. Schroeder of the CBS-Chicago technical staf, under
the direction of J. J. J3eloungy, and has been used at
station WBB M since 1945. Additional amplifiers, based
upon this development, are in service in other Columbia
Broadcasting System stations and are also available
commercially from a well-known manufacturer.
I'd rather not make a new thread, so I'll put this here.
Dynamic Performance of Peak-Limiting Amplifier (PDF page 207)
https://worldradiohistory.com/Archive-IRE/40s/IRE-1947-11.pdf
At the end of the article there is described a feedforward limiter with power amplifier is driving driving the rectifier to create control voltage. Has anyone seen a schematic for this limiter?
EDIT: GE BE-5-A seems to fit the description
https://worldradiohistory.com/Archive-Bell-System-Technical-Journal/30s/Bell-1934c.o.pdfA compandor system has been in service on the New York-London long-wave radiotelephone circuit since about July 1, 1932.
The circuits as shown use variable shunt control for the compressor and variable series control for the expandor. Either or both may be changed to the other by inverting the polarity of the control potential and properly designing the rectifier characteristics of the control circuits.
No, nothing new coming except improvements on some of my older designs.Are you going to design a new interesting device?
